Asus X551CA Hard Drive Replacement
  1. Asus X551CA Hard Drive Replacement, Keyboard Plate Cover: step 1, image 1 of 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Hard Drive Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Hard Drive Replacement: step 3, image 1 of 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Hard Drive Replacement: step 4, image 1 of 3 Asus X551CA Hard Drive Replacement: step 4, image 2 of 3 Asus X551CA Hard Drive Replacement: step 4, image 3 of 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Hard Drive Replacement: step 5, image 1 of 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Hard Drive Replacement, Hard Drive: step 6, image 1 of 1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  7. Asus X551CA Hard Drive Replacement: step 7, image 1 of 1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  8. Asus X551CA Hard Drive Replacement: step 8, image 1 of 1
    • Once free, remove the hard drive from its internal cavity.
Brandon
2,828 Reputation
1 Guide authored
Cal Poly, Team 7-22, Regan Spring 2014 Member of Cal Poly, Team 7-22, Regan Spring 2014
CPSU-REGAN-S14S7G22
5 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 66,563
