Asus X515 Ram Replacement
    1. Asus X515 Ram Replacement, Flip over laptop: step 1, image 1 of 2 Asus X515 Ram Replacement, Flip over laptop: step 1, image 2 of 2
      • Power the laptop down and unplug all of the cables.
      • Flip over the laptop.
      Ask FixBot
    2. Asus X515 Ram Replacement, Take off bottom cover: step 2, image 1 of 2 Asus X515 Ram Replacement, Take off bottom cover: step 2, image 2 of 2
      • Remove the 10 phillips screws from the bottom of the case.
      • Using a prying tool pry the bottom of the case open.
      Ask FixBot
    3. Asus X515 Ram Replacement, Disconnect battery: step 3, image 1 of 3 Asus X515 Ram Replacement, Disconnect battery: step 3, image 2 of 3 Asus X515 Ram Replacement, Disconnect battery: step 3, image 3 of 3
      • Locate the battery and its connector.
      • Using your fingers or a prying tool pull up on the connector to disconnect it.
      Ask FixBot
    4. Asus X515 Ram Replacement, Remove RAM: step 4, image 1 of 3 Asus X515 Ram Replacement, Remove RAM: step 4, image 2 of 3 Asus X515 Ram Replacement, Remove RAM: step 4, image 3 of 3
      • Locate the stick of RAM.
      • Using your fingers, pull the metal arms on the sides of the RAM away from it.
      • The RAM will face upwards.
      • Remove the RAM from its slot by pulling it out.
      Ask FixBot
5 other people completed this guide.
Jeremiah C.
847 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 53
Past 30 Days: 210
All Time: 1,877
