Asus X200MA Trackpad Replacement
  1. Asus X200MA Trackpad Replacement, Back Panel: step 1, image 1 of 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Trackpad Replacement: step 2, image 1 of 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Trackpad Replacement: step 3, image 1 of 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Trackpad Replacement, Trackpad: step 4, image 1 of 2 Asus X200MA Trackpad Replacement, Trackpad: step 4, image 2 of 2
    • Use the spudger to lift up and remove the black plastic covering.
  5. Asus X200MA Trackpad Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Remove thinner white strip by first flipping up black piece at the top of the strip with the tweezers and then pulling it out.
  6. Asus X200MA Trackpad Replacement, Mouse: step 6, image 1 of 1
    • Remove wider blue strip with tweezers.
  7. Asus X200MA Trackpad Replacement: step 7, image 1 of 1
    • Remove the following eight screws:
    • Eight 3 mm screws using Phillips #0 screwdriver.
  8. Asus X200MA Trackpad Replacement: step 8, image 1 of 1
    • Remove the following two screws after lifting metal plate off:
    • Two 2 mmm screws using a Phillips #0 screwdriver.
  9. Asus X200MA Trackpad Replacement: step 9, image 1 of 2 Asus X200MA Trackpad Replacement: step 9, image 2 of 2
    • Use metal spudger to get in between mouse pad and keyboard and lift off.
Vanessa Garcia
1,763 Reputation
6 Guides authored
Cal Poly, Team 21-24, Maness Winter 2015 Member of Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 16
All Time: 2,108
