Asus X200CA Keyboard Replacement
  1. Asus X200CA Keyboard Replacement, Keyboard: step 1, image 1 of 2 Asus X200CA Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Keyboard Replacement: step 2, image 1 of 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Keyboard Replacement: step 3, image 1 of 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
Jacqueline Collier
1,047 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Leahy Fall 2017 Member of USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,052
