Asus W2W-A1 Keyboard Replacement
  1. Asus W2W-A1 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Asus W2W-A1 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Asus W2W-A1 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Keyboard Replacement: step 2, image 1 of 1
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Keyboard Replacement: step 3, image 1 of 1
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Keyboard Replacement: step 4, image 1 of 2 Asus W2W-A1 Keyboard Replacement: step 4, image 2 of 2
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
Joe Redfearn
97 Reputation
1 Guide authored
Cal Poly, Team 13-29, Maness Spring 2014 Member of Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 245
