Introduction
If your hinges are broken or stuck, use this guide to replace them. This repair can be completed by one person using a PH1 Philips Head Screwdriver. Keep in mind that the Asus Vivobook S500CA uses a specific hinge mount points, these parts must be acquired before beginning this replacement.
Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
Open the device to access the plastic casing over the hinges.
Remove the casing by lifting firmly. This step can be difficult.
Remove 4 (.5 cm) screws from the hinge. Remove the hinge and follow steps in reverse order to reassemble and complete repair.
