Introduction
If your hinges are broken or stuck, use this guide to replace them. This repair can be completed by one person using a PH1 Philips Head Screwdriver. Keep in mind that the Asus Vivobook S500CA uses a specific hinge mount points, these parts must be acquired before beginning this replacement.
Open the device to access the plastic casing over the hinges.
Remove the casing by lifting firmly. This step can be difficult.
I had to puzzle out this procedure myself on a VivoBook S400C, and in the process I found that you simply have to slide the hinge cover 3 mm (1/8 inch) to the right, and at that point it pops right out. I strongly suspect this laptop may use the same procedure.
One Comment
Hi.
The Asus X550C set screen (screen + flat cable) is compatible with Asus S500CA notebook? Anybody know response for me? Tks
