Introduction
If your fan is either broken or not running correctly, use this guide to replace it. This repair can be completed by one person using a PH1 Philips Head Screwdriver. Keep in mind that the Asus Vivobook S500CA uses a specific model fan, which must be acquired before beginning this replacement.
Use a Phillips Head PH1 screwdriver to remove 10 screws around the perimeter of the back plate.
Remove 2 (.5 cm) Phillips Head screws found around the fan and 4 (.3 cm) Phillips Head screws found around the heat sink connector.
Unhook the electronic connection located above the fan by pulling the white connector straight out of the brown socket.
