Introduction
The tablet comes with two cameras. Replacing the back camera will be the sole focus of this guide.
Place the device face down on a flat surface.
Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
