Asus VivoBook X540SA-BPD0602V Battery Removal
  1. Asus VivoBook X540SA-BPD0602V Battery Removal, Keyboard: step 1, image 1 of 1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Battery Removal: step 2, image 1 of 1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Battery Removal: step 3, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Battery Removal: step 4, image 1 of 1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Battery Removal: step 5, image 1 of 1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Battery Removal: step 6, image 1 of 1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Battery Removal, Battery: step 7, image 1 of 1
    • After removing the keyboard, locate the lithium ion battery pack along the top of the device.
  8. Asus VivoBook X540SA-BPD0602V Battery Removal: step 8, image 1 of 1
    • Very carefully, remove the batteries with the same blue plastic iFixit opening tool used in the first tutorial. Focus your efforts on the combed hinge to the left of the batteries.
    • Be careful not to rip any of the black plastic or the wrap covering around the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not use them.
Jessica Browne
978 Reputation
6 Guides authored
USF Tampa, Team S1-G111, Cagle Fall 2017 Member of USF Tampa, Team S1-G111, Cagle Fall 2017
USFT-CAGLE-F17S1G111
5 Members
14 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 80
All Time: 9,425
