Asus Q200E Keyboard Replacement
  1. Asus Q200E Keyboard Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus Q200E Keyboard Replacement: step 2, image 1 of 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus Q200E Keyboard Replacement: step 3, image 1 of 2 Asus Q200E Keyboard Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus Q200E Keyboard Replacement, Motherboard: step 4, image 1 of 1
    • Locate the motherboard under the cooling fan.
  5. Asus Q200E Keyboard Replacement: step 5, image 1 of 1
    • Unscrew the two 5.9mm screws on the PCB board with a Phillips #0 screwdriver.
  6. Asus Q200E Keyboard Replacement: step 6, image 1 of 1
    • Remove the PCB board from the motherboard.
  7. Asus Q200E Keyboard Replacement: step 7, image 1 of 1
    • Unscrew the four 5.9mm hard drive bracket screws with a Phillips #0 screwdriver.
  8. Asus Q200E Keyboard Replacement: step 8, image 1 of 2 Asus Q200E Keyboard Replacement: step 8, image 2 of 2
    • Unscrew the four 5.9mm screws with a Phillips #0 screwdriver.
    • Next, carefully lift the LAN bracket out of the slot.
  9. Asus Q200E Keyboard Replacement: step 9, image 1 of 1
    • Remove the five 5.9mm screws holding the motherboard in place with a Phillips #0 screwdriver.
    • Remove the five 3.5mm screws holding the motherboard with a Phillips #00 screwdriver.
  10. Asus Q200E Keyboard Replacement: step 10, image 1 of 1
    • Carefully lift the motherboard up out of the slot.
  11. Asus Q200E Keyboard Replacement: step 11, image 1 of 2 Asus Q200E Keyboard Replacement: step 11, image 2 of 2
    • Locate and unplug the power bus from the motherboard.
    • The motherboard can now be replaced.
  12. Asus Q200E Keyboard Replacement, Battery: step 12, image 1 of 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  13. Asus Q200E Keyboard Replacement: step 13, image 1 of 3 Asus Q200E Keyboard Replacement: step 13, image 2 of 3 Asus Q200E Keyboard Replacement: step 13, image 3 of 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  14. Asus Q200E Keyboard Replacement: step 14, image 1 of 2 Asus Q200E Keyboard Replacement: step 14, image 2 of 2
    • Now just lift the battery out of place.
  15. Asus Q200E Keyboard Replacement, Trackpad: step 15, image 1 of 1
    • Disconnect the small blue TP(trackpad) labeled data bus.
  16. Asus Q200E Keyboard Replacement: step 16, image 1 of 1
    • Identify the ten 2.94mm screws on the metal bracket.
  17. Asus Q200E Keyboard Replacement: step 17, image 1 of 1
    • Unscrew the ten 2.94mm screws with the Philips #00 Head.
  18. Asus Q200E Keyboard Replacement: step 18, image 1 of 1
    • Remove all of the metallic tape holding the metal bracket to the components surrounding it.
  19. Asus Q200E Keyboard Replacement: step 19, image 1 of 1
    • Lift the metal bracket away from the laptop.
  20. Asus Q200E Keyboard Replacement: step 20, image 1 of 1
    • Unscrew the four 3.5mm screws with Phillips #00 Head.
    • This black plastic panel holds the trackpad in place.
  21. Asus Q200E Keyboard Replacement: step 21, image 1 of 1
    • Lift the trackpad up from the laptop and slide it out of the housing.
  22. Asus Q200E Keyboard Replacement, Cooling Fan: step 22, image 1 of 1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  23. Asus Q200E Keyboard Replacement: step 23, image 1 of 1
    • Unplug the power bus for the fan.
  24. Asus Q200E Keyboard Replacement: step 24, image 1 of 1
    • Lift up and remove the cooling fan from the slot.
  25. Asus Q200E Keyboard Replacement, Keyboard: step 25, image 1 of 2 Asus Q200E Keyboard Replacement, Keyboard: step 25, image 2 of 2
    • Next, unscrew the two 4.9mm hinge screws with a Phillips #00 screwdriver.
  26. Asus Q200E Keyboard Replacement: step 26, image 1 of 2 Asus Q200E Keyboard Replacement: step 26, image 2 of 2
    • Remove the ten 4.9mm screws holding the metal keyboard panel in place, using a Phillips #00 screwdriver.
    • Carefully lift the metal keyboard panel out of the slot.
  27. Asus Q200E Keyboard Replacement: step 27, image 1 of 1
    • Pull the display hinges back in order to remove the metal keyboard panel.
  28. Asus Q200E Keyboard Replacement: step 28, image 1 of 1
    • Carefully pry and loosen the keyboard from the slot.
  29. Asus Q200E Keyboard Replacement: step 29, image 1 of 2 Asus Q200E Keyboard Replacement: step 29, image 2 of 2
    • Carefully lift the keyboard out of the slot.
Mitchell Jackson
742 Reputation
7 Guides authored
IUPUI, Team S4-G4, Wilson Summer 2017 Member of IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,229
