Asus VivoBook Q200E-BSI3T08 Display Replacement
  1. Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: step 1, image 1 of 2 Asus VivoBook Q200E-BSI3T08 Display Replacement, Display: step 1, image 2 of 2
    • First open the laptop and place it so that you have access to the side of the display.
    • Next you want to place the laptop in a position where you have easy access to the display.
    • Use a metal or a plastic prying tool to split the front and back of the display.
    • Start on the side and work your way around.
  2. Asus VivoBook Q200E-BSI3T08 Display Replacement: step 2, image 1 of 2 Asus VivoBook Q200E-BSI3T08 Display Replacement: step 2, image 2 of 2
    • Pull the clear plastic display down from the bottom right and left.
    • If pulled from the top you might crack the actual plastic.
  3. Asus VivoBook Q200E-BSI3T08 Display Replacement: step 3, image 1 of 1
    • Remove the two 2.8mm screws on the top right and top left of the screen using a Phillips #0 screwdriver.
  4. Asus VivoBook Q200E-BSI3T08 Display Replacement: step 4, image 1 of 1
    • Remove the two 2.8 screws on the bottom right and left using a Phillips #0 screwdriver.
  5. Asus VivoBook Q200E-BSI3T08 Display Replacement: step 5, image 1 of 1
    • Once the screws are removed you should be able to move the display down. Be careful as there is a connection to the motherboard which will need to be removed.
  6. Asus VivoBook Q200E-BSI3T08 Display Replacement: step 6, image 1 of 1
    • Here is a picture of the connection that needs to be removed to free the display.
    • Pull connection from the plastic on the sides not the wires as these are fragile.
  7. Asus VivoBook Q200E-BSI3T08 Display Replacement: step 7, image 1 of 2 Asus VivoBook Q200E-BSI3T08 Display Replacement: step 7, image 2 of 2
    • Once this connection is removed here's what that should look.
  8. Asus VivoBook Q200E-BSI3T08 Display Replacement: step 8, image 1 of 1
    • Remove display and place your new one in it's place.
Mitchell Jackson
742 Reputation
7 Guides authored
IUPUI, Team S4-G4, Wilson Summer 2017 Member of IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 1,846
