Asus Q200E Cooling Fan Replacement
  1. Asus Q200E Cooling Fan Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus Q200E Cooling Fan Replacement: step 2, image 1 of 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus Q200E Cooling Fan Replacement: step 3, image 1 of 2 Asus Q200E Cooling Fan Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus Q200E Cooling Fan Replacement, Cooling Fan: step 4, image 1 of 1
    • Unscrew the five 4.9mm screws holding the cooling fan in place using a Phillips #0 screwdriver.
  5. Asus Q200E Cooling Fan Replacement: step 5, image 1 of 1
    • Unplug the power bus for the fan.
  6. Asus Q200E Cooling Fan Replacement: step 6, image 1 of 1
    • Lift up and remove the cooling fan from the slot.
Mitchell Jackson
742 Reputation
7 Guides authored
IUPUI, Team S4-G4, Wilson Summer 2017 Member of IUPUI, Team S4-G4, Wilson Summer 2017
IUPUI-WILSON-SU17S4G4
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 518
