Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
