Introduction
This replacement guide will teach you how to remove the fan from your Asus V6800V and information on how to clean it.
Place the computer upside down.
Using your thumbs, slide both latches away from each other (towards the outside).
Push the battery out with your fingers.
Use the Phillips #0 to remove the six screws on the back of the device.
Gently open the cover using the tab located by the highlighted box.
Grab the set of wires that you disconnected earlier and pull straight up. The fan should remove easily.
Use a cotton swab or compressed air to blow air from the inside, out to clear dust from vent or heat sink.
