Asus V6800V CD/DVD Drive Replacement
  1. Asus V6800V CD/DVD Drive Replacement, Battery: step 1, image 1 of 2 Asus V6800V CD/DVD Drive Replacement, Battery: step 1, image 2 of 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V CD/DVD Drive Replacement, Hard Drive: step 2, image 1 of 2 Asus V6800V CD/DVD Drive Replacement, Hard Drive: step 2, image 2 of 2
    • Remove the two screws using a Phillips #0 screwdriver.
  3. Asus V6800V CD/DVD Drive Replacement: step 3, image 1 of 2 Asus V6800V CD/DVD Drive Replacement: step 3, image 2 of 2
    • Pry open the case using an iFixit opening tool.
    • Actual hard drive is not shown in the second image.
  4. Asus V6800V CD/DVD Drive Replacement: step 4, image 1 of 2 Asus V6800V CD/DVD Drive Replacement: step 4, image 2 of 2
    • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
    • Second image shows what it should look like once you remove the hard drive.
  5. Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: step 5, image 1 of 2 Asus V6800V CD/DVD Drive Replacement, CD/DVD Drive: step 5, image 2 of 2
    • First, remove the highlighted screw (bottom right corner in the picture.)
    • Using any tool that fits into the highlighted hole, carefully push CD/DVD drive out.
Jong Park
114 Reputation
5 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 4,275
