Introduction
Are you unable to connect to any WiFi connection? If so, then you might be experiencing a faulty WiFi card. This guide will take you through all the steps required to replace your Asus Flip Book WiFi card.
Tool used on this step:Tweezers$4.99
The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
Gently remove the Wifi cables hooked to the rim of the battery
Remove the battery
Unscrew the WiFi card with a JIS #000 screwdriver.
Remove the motherboard connection from the WiFi card with tweezers.
Pull out the WiFi card.
