Asus Transformer Flip Book TP200S LCD Screen Replacement
  1. Asus Transformer Flip Book TP200S LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Asus Transformer Flip Book TP200S LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
    • Open your flip book so that the screen faces towards you. You will notice 2 rubber pads at the base of the screen.
    • Using a metal spudger, lift the rubber pads off to find 2 screen 3mm screws. Unscrew these 3mm screw with a phillips head J000 screwdriver.
  2. Asus Transformer Flip Book TP200S LCD Screen Replacement: step 2, image 1 of 2 Asus Transformer Flip Book TP200S LCD Screen Replacement: step 2, image 2 of 2
    • After removing the screws, use the metal spudger to gentle pry open the screen casing from the flip book casing.
  3. Asus Transformer Flip Book TP200S LCD Screen Replacement: step 3, image 1 of 2 Asus Transformer Flip Book TP200S LCD Screen Replacement: step 3, image 2 of 2
    • Gently remove all the connections and tape you see attached to the screen with tweezers.
  4. Asus Transformer Flip Book TP200S LCD Screen Replacement: step 4, image 1 of 1
    • After all connections have been removed, use the metal spudger and pry the screen itself from the screen casing.
    • Caution: The screen is glued to the screen casing with adhesive so you will need to exert some force to get the screen off. This will likely damage your old screen permanently. Be certain you have a replacement readily available before you engage in this step.
    • You will not need to reapply the adhesive.
Alejandro Lopez
662 Reputation
5 Guides authored
USF Tampa, Team S17-G2, Boczar Spring 2018 Member of USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 1,697
