Asus ROG Strix GL702VS Trackpad Replacement
    1. Asus ROG Strix GL702VS Trackpad Replacement, Back Cover: step 1, image 1 of 1
      • Flip the computer so the bottom of the laptop is facing up.
      Ask FixBot
    2. Asus ROG Strix GL702VS Trackpad Replacement: step 2, image 1 of 1
      • Remove the ten JIS #0 screws around the edge of the laptop.
      • The two bottom screws are slightly shorter
      Ask FixBot
    3. Asus ROG Strix GL702VS Trackpad Replacement: step 3, image 1 of 2 Asus ROG Strix GL702VS Trackpad Replacement: step 3, image 2 of 2
      • Use a Jimmy to carefully free each side of the bottom casing.
      Ask FixBot
    4. Asus ROG Strix GL702VS Trackpad Replacement: step 4, image 1 of 1
      • Lift up the back casing from the computer.
      • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
      Ask FixBot
    1. Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: step 5, image 1 of 3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: step 5, image 2 of 3 Asus ROG Strix GL702VS Trackpad Replacement, Trackpad: step 5, image 3 of 3
      • Disconnect the ribbon cables from the connectors at the bottom of the motherboard by lifting up the tabs with a nylon spudger tool.
      • Slide the ribbon cables out of the connectors on the motherboard.
      Ask FixBot
    2. Asus ROG Strix GL702VS Trackpad Replacement: step 6, image 1 of 2 Asus ROG Strix GL702VS Trackpad Replacement: step 6, image 2 of 2
      • Remove the covering foil holding the trackpad into place.
      • Completely peel the foil back to ensure it does not interfere with the following processes.
      Ask FixBot
    3. Asus ROG Strix GL702VS Trackpad Replacement: step 7, image 1 of 2 Asus ROG Strix GL702VS Trackpad Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Lift up speaker cable that is laying overtop using a pair of tweezers.
      • Do not to overextend the wire since you may accidently pull the wire out.
      Ask FixBot
    4. Asus ROG Strix GL702VS Trackpad Replacement: step 8, image 1 of 3 Asus ROG Strix GL702VS Trackpad Replacement: step 8, image 2 of 3 Asus ROG Strix GL702VS Trackpad Replacement: step 8, image 3 of 3
      • Remove the three 4mm JIS #0 screws that are securing the trackpad.
      Ask FixBot
    5. Asus ROG Strix GL702VS Trackpad Replacement: step 9, image 1 of 2 Asus ROG Strix GL702VS Trackpad Replacement: step 9, image 2 of 2
      • Once freed, slide the trackpad backwards towards the center of laptop.
      • This may require some jiggling. Lifting the laptop off your working surface may help.
      • Sliding the trackpad back in can be a bit tricky. Ensure it is fully seated before continuing reassembly.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 67
All Time: 1,485
