Introduction
This guide explains how to remove the screen of the Asus ROG Strix GL702VM-BHI7N09 for replacement. This replacement involves numerous screws and snap seals that add to the time it takes to replace; however, it is not a very difficult replacement.
Flip the laptop over to the back panel, with the serial numbers facing up.
Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
Once you have broken all the seals, carefully lift the panel off.
Using a Phillips #1 screwdriver, remove the one 4 mm screw from the motherboard to release the Intel chip.
Disconnect the black wire adjacent to the fan from the motherboard by gently pulling it upward.
While holding down the screen, lift the base of the laptop to an angle between 45 and 90 degrees.
Remove the screen from the base by gently pulling the base in the direction of the screen, parallel to the ground.
Using the blue plastic opening tool, pry up the squares that cover two screws on the front of the screen.
Use the plastic opening tool to pry the plastic covering away from the screen, it does not matter where you start.
Gently peel off the tape over the wire connection.
Disconnect the wire by pulling it directly away from the screen.
