Asus ROG GL551J Screen Replacement
    1. Asus ROG GL551J Screen Replacement, Battery: step 1, image 1 of 1
      • Lay the device on a flat surface with the battery facing up.
      • Be sure to wear ESD or Rubber gloves to protect the computer components.
      Ask FixBot
    2. Asus ROG GL551J Screen Replacement: step 2, image 1 of 1
      • Push the latch found below the battery to the unlock position.
      Ask FixBot
    3. Asus ROG GL551J Screen Replacement: step 3, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Asus ROG GL551J Screen Replacement, Screen: step 4, image 1 of 2 Asus ROG GL551J Screen Replacement, Screen: step 4, image 2 of 2
      • Use a plastic opening tool to remove the plastic hinge covers on either side of the laptop.
      Ask FixBot
    2. Asus ROG GL551J Screen Replacement: step 5, image 1 of 2 Asus ROG GL551J Screen Replacement: step 5, image 2 of 2
      • Remove the middle screws located on either side of the display.
      Ask FixBot
    3. Asus ROG GL551J Screen Replacement: step 6, image 1 of 2 Asus ROG GL551J Screen Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to pop out the bezel from all four sides, then lift it out of the frame.
      • When doing this in reverse during reassembly, try closing the laptop and applying pressure to reattach the bezel snaps.
      Ask FixBot
    4. Asus ROG GL551J Screen Replacement: step 7, image 1 of 1
      • Remove the screws at each corner of the display.
      Ask FixBot
    5. Asus ROG GL551J Screen Replacement: step 8, image 1 of 2 Asus ROG GL551J Screen Replacement: step 8, image 2 of 2
      • Remove the connector from the display by pulling the wire downwards.
      • Be sure to take note of the orientation of the connector when unplugging and plugging in.
      Ask FixBot
Thien Vu
412 Reputation
2 Guides authored
USF Tampa, Team 5-4, Lacy Spring 2017 Member of USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Members
60 Guides authored
1 Guide Comment
Hey, I am having issues putting the plastic hinge caps back on after I'm done. I know there is a right one and a left one but I just don't know how to pop them back into place. Starting to get a bit desperate. Could anyone give me some tips?
Thanks!
Teodor Andonov - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 103
All Time: 3,810
