Introduction
This guide will teach you how to replace the Central Processing Unit in your device. This is important for the usability of the device.
Lift the rubber cover found on the bottom of the laptop.
Remove the 5.2 mm screw with a Phillips 1 Screwdriver
2 Comments
Hi Justin, if I were to remove the motherboard and insert a new one using your procedure would I have to change anything in the bios or will just a physical switch do the thing.
I was following this guide normally but then I saw the last step... are you f***ing kidding me?! You DO NOT PRY OFF that chip!! It's a BGA connection and you WILL destroy it. If you need your CPU or GPU replaced, either buy a new motherboard or seek a professional's service that replaces chips like that. But yikes, an iFixit guide that's pretty coherent yet the last step implies removing the chip and damaging it... I must be hallucinating. If anyone did mindlessly follow this guide without prior experience... you have my deepest condolences.
