Asus ROG G751JL-BB17T29 RAM Access Door Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Asus ROG G751JL-BB17T29 RAM Access Door Replacement, Remove the RAM Access Door: step 1, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Access Door Replacement, Remove the RAM Access Door: step 1, image 2 of 2
    • Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
  2. Asus ROG G751JL-BB17T29 RAM Access Door Replacement: step 2, image 1 of 1
    • Remove the 5.3 mm Phillips #00 screw securing the RAM access door.
    • This screw is held in the hole in the door with a washer and will not come out of the hole, even after you unscrew it.
  3. Asus ROG G751JL-BB17T29 RAM Access Door Replacement: step 3, image 1 of 2 Asus ROG G751JL-BB17T29 RAM Access Door Replacement: step 3, image 2 of 2
    • Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
    • The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
  4. Asus ROG G751JL-BB17T29 RAM Access Door Replacement: step 4, image 1 of 3 Asus ROG G751JL-BB17T29 RAM Access Door Replacement: step 4, image 2 of 3 Asus ROG G751JL-BB17T29 RAM Access Door Replacement: step 4, image 3 of 3
    • Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
    • Pry the door up to release the clips closest to the pick.
    • Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
  5. Asus ROG G751JL-BB17T29 RAM Access Door Replacement: step 5, image 1 of 1
    • Remove the RAM access door.
Adam O'Camb
197,118 Reputation
416 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 50
