Use an opening tool to pry up the small rubber cover on the upper right corner of the RAM access door.
Insert the point of an opening pick in the seam near the top right corner of the RAM access door and gently pry the door up slightly.
The door is held in place by small clips around its edges. Pry until you feel the nearest clips release.
Insert the wide edge of an opening pick into a new part of the seam between the door and the computer.
Pry the door up to release the clips closest to the pick.
Continue to slide the pick along the seam all the way around the door, prying as you go, until all the clips holding the door down have been released.
Remove the four 2.4 mm screws securing the left hard drive with a Phillips screwdriver.
Use the pull-tab to lift the hard drive housing and pull the hard drive away from the connector.
Remove the four 2.4 mm screws securing the right hard drive housing with a Phillips screwdriver.
