Introduction
How to detach and reattach palmrest part (the plate with keyboard, touchpad, power button etc.)
Locate and unscrew the screw under the rubber cover
pop out the plastic cover
unscrew 5 screws marked in the picture (keep the screws separated by length and color)
pop out the rubbers plugs (7) around the laptop
unscrew screws under the plugs
If you have removed screw C in step 3 (pointed at in the picture) you can pull out the optical drive
remove all 3 screws revealed by removing the drive
flip laptop
pop open the speaker part
unplug speakers
remove 1 black screw on both sides
using a plastic prying tool separate the front plate(keyboard) from the rest of the laptop
gently lift the front plate
detach all four ribbons connecting the front plate to the motherboard
keep the light colored ribbon (it can be detached from the front plate as well)
connect the new front plate in the same spots as the old one
if needed reconnect the light colored ribbon on both the front plate and the motherboard
push the new plate back in place, make sure all sides are in
reconnect the speakers
push in place the whole speaker panel
screw back the 3 screws in the optical drive slot
slide in the drive
secure with screw C (circled in second picture)
put in place all screws in the back panel
the screw on the very left is the longest
push back in the plastic cover
return the silver screw covered by the rubber cover
screw in the last 5 screws in the battery panel
push back in the battery
done!
2 other people completed this guide.
2 Comments
what does the light ribbon do?
@Anthony+Massmann I don’t remember exactly. It’s most likely for the touch pad considering it’s location.
