Asus ROG G750JS keyboard (palmrest) Replacement
  1. Asus ROG G750JS keyboard (palmrest) Replacement, pull out battery: step 1, image 1 of 1
    • Flip the laptop
    • Unlock and pull out the battery
  2. Asus ROG G750JS keyboard (palmrest) Replacement, unscrew back panel access: step 2, image 1 of 3 Asus ROG G750JS keyboard (palmrest) Replacement, unscrew back panel access: step 2, image 2 of 3 Asus ROG G750JS keyboard (palmrest) Replacement, unscrew back panel access: step 2, image 3 of 3
    • Locate and unscrew the screw under the rubber cover
    • pop out the plastic cover
    • unscrew 5 screws marked in the picture (keep the screws separated by length and color)
  3. Asus ROG G750JS keyboard (palmrest) Replacement, unscrew the outer screws: step 3, image 1 of 1
    • pop out the rubbers plugs (7) around the laptop
    • unscrew screws under the plugs
  4. Asus ROG G750JS keyboard (palmrest) Replacement, remove screws under battery: step 4, image 1 of 1
    • remove 5 screws from the battery panel
  5. Asus ROG G750JS keyboard (palmrest) Replacement, remove optical drive: step 5, image 1 of 1
    • If you have removed screw C in step 3 (pointed at in the picture) you can pull out the optical drive
    • remove all 3 screws revealed by removing the drive
  6. Asus ROG G750JS keyboard (palmrest) Replacement, remove speakers: step 6, image 1 of 3 Asus ROG G750JS keyboard (palmrest) Replacement, remove speakers: step 6, image 2 of 3 Asus ROG G750JS keyboard (palmrest) Replacement, remove speakers: step 6, image 3 of 3
    • flip laptop
    • pop open the speaker part
    • unplug speakers
    • remove 1 black screw on both sides
  7. Asus ROG G750JS keyboard (palmrest) Replacement, pop out the front plate: step 7, image 1 of 1
    • using a plastic prying tool separate the front plate(keyboard) from the rest of the laptop
  8. Asus ROG G750JS keyboard (palmrest) Replacement, detach the keyboard: step 8, image 1 of 2 Asus ROG G750JS keyboard (palmrest) Replacement, detach the keyboard: step 8, image 2 of 2
    • gently lift the front plate
    • detach all four ribbons connecting the front plate to the motherboard
    • keep the light colored ribbon (it can be detached from the front plate as well)
  9. Asus ROG G750JS keyboard (palmrest) Replacement, connect and push in the new part: step 9, image 1 of 2 Asus ROG G750JS keyboard (palmrest) Replacement, connect and push in the new part: step 9, image 2 of 2
    • connect the new front plate in the same spots as the old one
    • if needed reconnect the light colored ribbon on both the front plate and the motherboard
    • push the new plate back in place, make sure all sides are in
  10. Asus ROG G750JS keyboard (palmrest) Replacement, put back the black screws: step 10, image 1 of 2 Asus ROG G750JS keyboard (palmrest) Replacement, put back the black screws: step 10, image 2 of 2
    • put back the black screws holding the front plate
  11. Asus ROG G750JS keyboard (palmrest) Replacement, reconnect and close the speaker panel: step 11, image 1 of 2 Asus ROG G750JS keyboard (palmrest) Replacement, reconnect and close the speaker panel: step 11, image 2 of 2
    • reconnect the speakers
    • push in place the whole speaker panel
  12. Asus ROG G750JS keyboard (palmrest) Replacement, put back the optical drive: step 12, image 1 of 2 Asus ROG G750JS keyboard (palmrest) Replacement, put back the optical drive: step 12, image 2 of 2
    • screw back the 3 screws in the optical drive slot
    • slide in the drive
    • secure with screw C (circled in second picture)
  13. Asus ROG G750JS keyboard (palmrest) Replacement, return back panel: step 13, image 1 of 3 Asus ROG G750JS keyboard (palmrest) Replacement, return back panel: step 13, image 2 of 3 Asus ROG G750JS keyboard (palmrest) Replacement, return back panel: step 13, image 3 of 3
    • put in place all screws in the back panel
    • the screw on the very left is the longest
    • push back in the plastic cover
    • return the silver screw covered by the rubber cover
  14. Asus ROG G750JS keyboard (palmrest) Replacement, put back in the battery: step 14, image 1 of 2 Asus ROG G750JS keyboard (palmrest) Replacement, put back in the battery: step 14, image 2 of 2
    • screw in the last 5 screws in the battery panel
    • push back in the battery
    • done!
2 other people completed this guide.
hornikmartinrepair
333 Reputation
1 Guide authored
2 Comments
what does the light ribbon do?
Anthony Massmann - Reply
@Anthony+Massmann I don’t remember exactly. It’s most likely for the touch pad considering it’s location.
hornikmartinrepair - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 917
