Asus R510LA-RS71 Screen Replacement
  1. Asus R510LA-RS71 Screen Replacement, Screen: step 1, image 1 of 3 Asus R510LA-RS71 Screen Replacement, Screen: step 1, image 2 of 3 Asus R510LA-RS71 Screen Replacement, Screen: step 1, image 3 of 3
    • Using a metal spudger, pick out the stoppers located on the bottom left/right corners of the screen, revealing the screws underneath them.
    • Unscrew the two 4.25mm screws with the JIS 00 screwdriver.
  2. Asus R510LA-RS71 Screen Replacement: step 2, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 2, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 2, image 3 of 3
    • Using the metal spudger, pry off the edges of the screen's frame from the outside.
  3. Asus R510LA-RS71 Screen Replacement: step 3, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 3, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 3, image 3 of 3
    • There should be four silver brackets holding the screen in place underneath. Unscrew the center 3.35mm screws in each bracket as shown with the JIS 00 screwdriver.
  4. Asus R510LA-RS71 Screen Replacement: step 4, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 4, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 4, image 3 of 3
    • Slowly remove the monitor from its recess.
  5. Asus R510LA-RS71 Screen Replacement: step 5, image 1 of 3 Asus R510LA-RS71 Screen Replacement: step 5, image 2 of 3 Asus R510LA-RS71 Screen Replacement: step 5, image 3 of 3
    • Place the monitor face down. Slowly remove the adhesive tape on the back of the monitor, and remove the connector that the tape is holding.
Deliyanis Rosa
283 Reputation
2 Guides authored
USF Tampa, Team S1-G6, Leahy Spring 2018 Member of USF Tampa, Team S1-G6, Leahy Spring 2018
USFT-LEAHY-S18S1G6
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 17
All Time: 466
