Asus R510LA-RS71 RAM Replacement
  1. Asus R510LA-RS71 RAM Replacement, RAM: step 1, image 1 of 2 Asus R510LA-RS71 RAM Replacement, RAM: step 1, image 2 of 2
    • Using the JIS 00 screwdriver, remove the bottom left/right 12.7mm screws located on the back of the laptop.
  2. Asus R510LA-RS71 RAM Replacement: step 2, image 1 of 2 Asus R510LA-RS71 RAM Replacement: step 2, image 2 of 2
    • Slide and lift off the bottom cover.
  3. Asus R510LA-RS71 RAM Replacement: step 3, image 1 of 3 Asus R510LA-RS71 RAM Replacement: step 3, image 2 of 3 Asus R510LA-RS71 RAM Replacement: step 3, image 3 of 3
    • There should be an exposed area located on the right center of the bottom of the revealed compartment. Move the silver brackets holding the RAM to the side. The RAM will pop out of its hold.
  4. Asus R510LA-RS71 RAM Replacement: step 4, image 1 of 1
    • Remove the RAM
Deliyanis Rosa
283 Reputation
2 Guides authored
USF Tampa, Team S1-G6, Leahy Spring 2018 Member of USF Tampa, Team S1-G6, Leahy Spring 2018
USFT-LEAHY-S18S1G6
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 387
