Asus Q502LA-BSI5T14 Battery Replacement
  1. Asus Q502LA-BSI5T14 Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Battery Replacement: step 2, image 1 of 1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Battery Replacement: step 3, image 1 of 2 Asus Q502LA-BSI5T14 Battery Replacement: step 3, image 2 of 2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Battery Replacement: step 4, image 1 of 2 Asus Q502LA-BSI5T14 Battery Replacement: step 4, image 2 of 2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
Mary Kounelas
715 Reputation
5 Guides authored
USF Tampa, Team S4-G1, Eyestone Fall 2017 Member of USF Tampa, Team S4-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S4G1
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 20
All Time: 4,413
