Asus PadFone S Motherboard Replacement
  1. Asus PadFone S Motherboard Replacement, Remove the Back Panel: step 1, image 1 of 1
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Motherboard Replacement, Remove the Back Panel: step 2, image 1 of 2 Asus PadFone S Motherboard Replacement, Remove the Back Panel: step 2, image 2 of 2
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Motherboard Replacement, Remove the Battery: step 3, image 1 of 2 Asus PadFone S Motherboard Replacement, Remove the Battery: step 3, image 2 of 2
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: step 4, image 1 of 3 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: step 4, image 2 of 3 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: step 4, image 3 of 3
    • Disconnect all wires and bands from microphone, SIM card port and side bottons
  5. Asus PadFone S Motherboard Replacement, Remove the Logic Board: step 5, image 1 of 3 Asus PadFone S Motherboard Replacement, Remove the Logic Board: step 5, image 2 of 3 Asus PadFone S Motherboard Replacement, Remove the Logic Board: step 5, image 3 of 3
    • Disconnect remaining band from the logic board
    • Lift the logic board out of the phone
2 other people completed this guide.
Greg Betsold
96 Reputation
3 Guides authored
One Comment
need schematic side button asus padfone s..please send via email kepkep.erwin@gmail.com.
thanks..
kepkep - Reply
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 16
All Time: 3,587
