Asus P53E replacement of hard drive or replacement by a SSD Replacement
  1. Asus P53E replacement of hard drive or replacement by a SSD Replacement, replacement of hard drive or replacement by a SSD: step 1, image 1 of 1
    • unscrew these two screws to remove the coverage
  2. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 2, image 1 of 1
    • unscrew these four screws to take out the case with the hard drive disk
  3. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 3, image 1 of 1
    • slip the hard drive to the left
  4. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 4, image 1 of 1
    • pull the strap to remove the hard drive's case
  5. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 5, image 1 of 1
    • unscrew the four screws of the case to remove the hard drive out of that case
  6. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 6, image 1 of 1
    • remove the hard drice from its case
  7. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 7, image 1 of 1
    • put the new hard drive or SSD, respectively in the case and fix the screws again (the HDD/SDD will only fit in the case in one way)
  8. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 8, image 1 of 1
    • slip the case to the right to plug in the HDD/SDD again
  9. Asus P53E replacement of hard drive or replacement by a SSD Replacement: step 9, image 1 of 1
    • close the case again
Mojo
113 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 18
All Time: 2,061
