Asus MeMo Pad 10 ME102A Back Panel Replacement
  1. Asus MeMo Pad 10 ME102A Back Panel Replacement, Back panel: step 1, image 1 of 1
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Back Panel Replacement: step 2, image 1 of 1
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Back Panel Replacement: step 3, image 1 of 1
    • After all of the clips have been opened, the back panel should be free to remove by hand
Andreas Niederer
426 Reputation
2 Guides authored
USF Tampa, Team 11-3, Blackwell Fall 2016 Member of USF Tampa, Team 11-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G3
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,753
