Asus K53E-BBR3 Optical Drive Replacement
  1. Asus K53E-BBR3 Optical Drive Replacement, Battery: step 1, image 1 of 3 Asus K53E-BBR3 Optical Drive Replacement, Battery: step 1, image 2 of 3 Asus K53E-BBR3 Optical Drive Replacement, Battery: step 1, image 3 of 3
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Optical Drive Replacement, Back Panel: step 2, image 1 of 1
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Optical Drive Replacement: step 3, image 1 of 1
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Optical Drive Replacement, Keyboard: step 4, image 1 of 3 Asus K53E-BBR3 Optical Drive Replacement, Keyboard: step 4, image 2 of 3 Asus K53E-BBR3 Optical Drive Replacement, Keyboard: step 4, image 3 of 3
    • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
    • Insert the spudger into the indent near the "ESC" key.
    • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
  5. Asus K53E-BBR3 Optical Drive Replacement: step 5, image 1 of 1
    • Gently pull the ribbon cable to the right and out of its port.
  6. Asus K53E-BBR3 Optical Drive Replacement, Optical Drive: step 6, image 1 of 3 Asus K53E-BBR3 Optical Drive Replacement, Optical Drive: step 6, image 2 of 3 Asus K53E-BBR3 Optical Drive Replacement, Optical Drive: step 6, image 3 of 3
    • On the back of the laptop unscrew the eighteen 5mm Phillips #1 screws.
    • Unscrew the two 5mm Phillips #1 screws.
    • The screws highlighted in orange are slightly thicker than those in red, however they are the same length and head type.
  7. Asus K53E-BBR3 Optical Drive Replacement: step 7, image 1 of 2 Asus K53E-BBR3 Optical Drive Replacement: step 7, image 2 of 2
    • Unscrew the four highlighted 5mm Phillips #1 screws, and remove the hard drive.
    • Unscrew the 3mm Phillips #1 screw.
  8. Asus K53E-BBR3 Optical Drive Replacement: step 8, image 1 of 1
    • Flip the laptop over and remove the seven 5mm Phillips #1 screws.
  9. Asus K53E-BBR3 Optical Drive Replacement: step 9, image 1 of 2 Asus K53E-BBR3 Optical Drive Replacement: step 9, image 2 of 2
    • There is a ribbon connector that is connecting the two halves of the laptop. So when opening the two plastic pieces be careful not to damage the cable.
    • Using the plastic opening tool, firmly pry apart the two sections of plastic.
    • Firmly shimmy the opening tool around the laptop prying the two sections of plastic apart.
    • Disconnect the highlighted ribbon cable, by pulling up on the black tab and gently pulling the cable out of its port.
  10. Asus K53E-BBR3 Optical Drive Replacement: step 10, image 1 of 2 Asus K53E-BBR3 Optical Drive Replacement: step 10, image 2 of 2
    • Unscrew the three 3mm Phillips #0 screws.
    • Slide the optical drive to the right.
    • Remove the optical drive.
Jacob O'Donnell
323 Reputation
3 Guides authored
UMass Dartmouth, Team 1-1, Catania Fall 2016 Member of UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 628
