Asus G73JW-XT1 Optical Drive Replacement
    1. Asus G73JW-XT1  Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Flip the device over so the battery port is easy to access.
      Ask FixBot
    2. Asus G73JW-XT1  Optical Drive Replacement: step 2, image 1 of 2 Asus G73JW-XT1  Optical Drive Replacement: step 2, image 2 of 2
      • Slide the left slider to the left so that it locks in place.
      • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
      Ask FixBot
    1. Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: step 3, image 1 of 2 Asus G73JW-XT1  Optical Drive Replacement, Optical Drive: step 3, image 2 of 2
      • Turn the device off and remove any power cords. Dissassembling the device while it is under power may result in electric shock and potential damage to the device.
      • Rotate the device so the battery port is facing away.
      • Remove two 5.5 mm Phillips #0 screws on the back panel.
      Ask FixBot
    2. Asus G73JW-XT1  Optical Drive Replacement: step 4, image 1 of 3 Asus G73JW-XT1  Optical Drive Replacement: step 4, image 2 of 3 Asus G73JW-XT1  Optical Drive Replacement: step 4, image 3 of 3
      • Insert the opener tool into the small groove at the edge of the panel.
      • Using opener tool, gently pry the back panel upward until it lifts free from the device.
      • Gently lift the panel off with your fingers.
      Ask FixBot
    3. Asus G73JW-XT1  Optical Drive Replacement: step 5, image 1 of 1
      • Remove one 5.5 mm Phillips #0 screw directly to the right of the RAM cards.
      Ask FixBot
    4. Asus G73JW-XT1  Optical Drive Replacement: step 6, image 1 of 2 Asus G73JW-XT1  Optical Drive Replacement: step 6, image 2 of 2
      • Insert the plastic opening tool in the gap between the motherboard and the back panel, directly to the right of the RAM cards.
      • Gently push the optical drive outwards. This should require very little pressure.
      • Grab the loose optical drive with your fingers and pull it free.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 688
