This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Asus G531G Battery Replacement
    1. Asus G531G Battery Replacement, Remove the screw: step 1, image 1 of 2 Asus G531G Battery Replacement, Remove the screw: step 1, image 2 of 2
      • Remove all the screws on the bottom.
      Ask FixBot
    2. Asus G531G Battery Replacement, Remove the upper left claw: step 2, image 1 of 1
      • Remove the top left screw.
      • If possible, please insert a pick.
      Ask FixBot
    3. Asus G531G Battery Replacement, Remove the screw on the left side: step 3, image 1 of 1
      • Remove the left claw.
      Ask FixBot
    4. Asus G531G Battery Replacement, Remove the screw at the upper right: step 4, image 1 of 1
      • Remove the top right claw.
      Ask FixBot
    5. Asus G531G Battery Replacement, Remove the right claw: step 5, image 1 of 1
      • Remove the claw on the right side
      Ask FixBot
    6. Asus G531G Battery Replacement, Remove the lower claw: step 6, image 1 of 1
      • Remove the lower claw.
      Ask FixBot
    7. Asus G531G Battery Replacement, Open the lid: step 7, image 1 of 1
      • Grab the side with the HDMI port and other ports and open the cover. Please refer to the image.
      Ask FixBot
    8. Asus G531G Battery Replacement, Remove the pin: step 8, image 1 of 2 Asus G531G Battery Replacement, Remove the pin: step 8, image 2 of 2
      • Remove the pin.
      Ask FixBot
    1. Asus G531G Battery Replacement, Power cord removal: step 9, image 1 of 2 Asus G531G Battery Replacement, Power cord removal: step 9, image 2 of 2
      • Move the silver part of the pin in the direction of the arrow.
      • At this time, do not pull any further if you feel resistance, as moving it too far will break the pin.
      Ask FixBot
    2. Asus G531G Battery Replacement, Cable Removal: step 10, image 1 of 3 Asus G531G Battery Replacement, Cable Removal: step 10, image 2 of 3 Asus G531G Battery Replacement, Cable Removal: step 10, image 3 of 3
      • Perform the removal of the white part of the cable.
      Ask FixBot
    3. Asus G531G Battery Replacement, Unscrew the battery: step 11, image 1 of 2 Asus G531G Battery Replacement, Unscrew the battery: step 11, image 2 of 2
      • Unscrew the battery.
      • The image shows one screw already removed, but that was just because I forgot to take the photo earlier ;)
      Ask FixBot
    4. Asus G531G Battery Replacement, Battery Removal: step 12, image 1 of 1
      • Remove the battery.
      • There is a risk of fire if the battery is bent or punctured. Handle with care.
      • Dispose of the removed battery in accordance with local regulations.
      Ask FixBot
To reassemble your device, install the new battery and
follow the following steps in reverse order.
Dispose of electronic waste properly according to your local guidelines.
Additionally, bending or puncturing the battery can cause a fire hazard. Handle it with care.
Repair Cat
2,932 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 119
All Time: 254
