Shop the Holiday Gift Guide
Asus F6A-X2 RAM Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
88
All Time:
1,212
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Introduction
Go to step 1 ↓
A better RAM means a faster computer. A faulty RAM can cause applications to crash or malfunction. Be sure to have RAM compatible with your laptop when replacing it.
Tools
    1. Asus F6A-X2 RAM Replacement, Battery: step 1, image 1 of 1
      • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
      • Flip laptop face down and rotate so the battery is facing toward you.
      • The battery is not shown in this picture.
      • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
      • Slide the battery toward you and lift it out of the laptop.
      Ask FixBot
    1. Asus F6A-X2 RAM Replacement, Back Access Panel: step 2, image 1 of 2 Asus F6A-X2 RAM Replacement, Back Access Panel: step 2, image 2 of 2
      • With the laptop facing down, rotate it so the battery pack is facing away from you.
      • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
      Ask FixBot
    2. Asus F6A-X2 RAM Replacement: step 3, image 1 of 3 Asus F6A-X2 RAM Replacement: step 3, image 2 of 3 Asus F6A-X2 RAM Replacement: step 3, image 3 of 3
      • Insert a finger into one of the slots on the bottom panel.
      • Gently lift the upwards, and the back panel of the laptop will come off easily.
      Ask FixBot
    1. Asus F6A-X2 RAM Replacement, RAM: step 4, image 1 of 2 Asus F6A-X2 RAM Replacement, RAM: step 4, image 2 of 2
      • Make sure to check the RAM specifications on the device page.
      • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
      • You will hear a pop and visibly see the RAM move upwards.
      • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
      Ask FixBot
    2. Asus F6A-X2 RAM Replacement: step 5, image 1 of 2 Asus F6A-X2 RAM Replacement: step 5, image 2 of 2
      • Repeat the process from the previous step to remove the bottom RAM.
      Ask FixBot
Author
with
Jonathan
1,174 Reputation
11 Guides authored
Cal Poly, Team 10-56, Amido Spring 2014 Member of Cal Poly, Team 10-56, Amido Spring 2014
CPSU-AMIDO-S14S10G56
4 Members
144 Guides authored
1 Guide Comment
Tutorel simple et très clair.
Merci
alainbadinier - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 88
All Time: 1,212
