Asus Eee PC 900 SSD Replacement
  1. Asus Eee PC 900 SSD Replacement, Battery: step 1, image 1 of 3 Asus Eee PC 900 SSD Replacement, Battery: step 1, image 2 of 3 Asus Eee PC 900 SSD Replacement, Battery: step 1, image 3 of 3
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 SSD Replacement: step 2, image 1 of 1
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 SSD Replacement, SSD: step 3, image 1 of 3 Asus Eee PC 900 SSD Replacement, SSD: step 3, image 2 of 3 Asus Eee PC 900 SSD Replacement, SSD: step 3, image 3 of 3
    • Remove the small sticker on the right side of the SSD/RAM compartment cover.
    • Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
  4. Asus Eee PC 900 SSD Replacement: step 4, image 1 of 2 Asus Eee PC 900 SSD Replacement: step 4, image 2 of 2
    • Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover.
    • Lift the cover away from the laptop.
  5. Asus Eee PC 900 SSD Replacement: step 5, image 1 of 3 Asus Eee PC 900 SSD Replacement: step 5, image 2 of 3 Asus Eee PC 900 SSD Replacement: step 5, image 3 of 3
    • Remove the two 4.76 mm Phillips #0 screws that secure the SSD.
    • When the screws are removed, one end of the SSD should pop up.
    • Slide the SSD out of its socket and lift it out of the compartment.
Brian Carreon
288 Reputation
2 Guides authored
Cal Poly, Team 3-27, Amido Winter 2012 Member of Cal Poly, Team 3-27, Amido Winter 2012
CPSU-AMIDO-W12S3G27
4 Members
16 Guides authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 128
All Time: 43,532
