Installing Asus Eee PC 1215N Top Cover
  1. Installing Asus Eee PC 1215N Top Cover, Battery: step 1, image 1 of 2 Installing Asus Eee PC 1215N Top Cover, Battery: step 1, image 2 of 2
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Installing Asus Eee PC 1215N Top Cover, RAM: step 2, image 1 of 3 Installing Asus Eee PC 1215N Top Cover, RAM: step 2, image 2 of 3 Installing Asus Eee PC 1215N Top Cover, RAM: step 2, image 3 of 3
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Installing Asus Eee PC 1215N Top Cover: step 3, image 1 of 1
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Installing Asus Eee PC 1215N Top Cover: step 4, image 1 of 2 Installing Asus Eee PC 1215N Top Cover: step 4, image 2 of 2
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Installing Asus Eee PC 1215N Top Cover, Top Cover (Touchpad): step 5, image 1 of 1
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Installing Asus Eee PC 1215N Top Cover: step 6, image 1 of 3 Installing Asus Eee PC 1215N Top Cover: step 6, image 2 of 3 Installing Asus Eee PC 1215N Top Cover: step 6, image 3 of 3
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  7. Installing Asus Eee PC 1215N Top Cover: step 7, image 1 of 2 Installing Asus Eee PC 1215N Top Cover: step 7, image 2 of 2
    Spudger
    $3.99
    Buy
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
Gaetan
9,574 Reputation
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 2,713
