Introduction
The hard drive is located under the keyboard of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in. Replacing the hard drive will require you to reinstall Windows on the laptop, so consider backing up your files before using the guide.
Warning: This guide causes warranty of laptop to be voided.
Start by placing the laptop upside-down on a flat surface.
Find the two clips on the back portion of the laptop.
Face the laptop so the 4 silver "clips" along the middle of the battery cartridge are in front of you.
Turn the laptop right side up and lift the lid.
Insert the flat end of the spudger into the small gap between the top of the keyboard and the plastic of the laptop.
Using the spudger as leverage, lift the keyboard up from the rest of the laptop.
Run the spudger across the seam until the entire top edge is exposed. The two sides of the keyboard should also pop up in this process.
Turn the laptop upside-down.
Find and unscrew the 6.65 mm Phillips #1 screw on the ram cover.
Locate the ribbon cable.
Using the flat end of the spudger push up the black clip that holds down the cable and pull the cable away from the clip.
12 other people completed this guide.
One Comment
When I did this one, I was not careful enough with the keyboard removal, somehow causing the trackpad to stop working. Still, keyboard worked, so just used an external mouse and had a nice SSD.
