Introduction
Use this guide to replace the keyboard in the Asus Eee PC 1005HA.
Tools
Parts
No parts specified.
The first step is to remove the battery from the laptop.
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
It must be mentioned that you need to put the plastic opening tool above the F1, F6, between F10 and F11 and the Insert (Num Lock) Keys . It has 4 clips in total.
10 other people completed this guide.
One Comment
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
