Introduction
Use this guide to replace or upgrade the hard drive in the Asus Eee PC 1005HA.
Slide the tabs outward to unlock the battery.
Holding the right tab open, slide the battery out of the laptop.
Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
Flip the laptop over, and open the display.
Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
Gently lift the keyboard and slide it toward the screen.
Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
Once the ZIF connector tabs have been released, remove the keyboard.
Flip the laptop over.
Remove the four 5.65 mm screws from the bottom of the case.
Loosen the captive screw in the RAM compartment cover.
Remove the panel covering the RAM.
Pull the two RAM retaining arms away from the center of the RAM chip.
Gently pull the RAM chip out of its socket.
Flip the laptop back over and open the display.
Remove the six 5.5 mm screws from the metal plate beneath the keyboard.
Using a plastic opening tool, carefully detach the five plastic clips securing the upper case.
Carefully lift the upper case and flip it towards the front of the laptop.
Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
Slide the trackpad ribbon cable from its socket.
Flip up the retaining flaps on each end of the I/O board ribbon cable ZIF connector.
Carefully pull the the I/O board ribbon cable from its sockets.
Remove the two 4.6 mm screws holding the hard drive in place.
Carefully slide the hard drive away from its socket.
Use the attached pull tab to lift the hard drive up and out of the case.
Remove the four 3.6 mm screws from the hard drive tray.
Remove the hard drive from the tray.
