Asus Chromebook Flip C302CA Speakers Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
56
All Time:
488
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
If the speakers in your Asus Chromebook Flip laptop (model C302CA) has no vibration, is disrupting without turning up the volume too high, is making noises like popping and rattling, or the system range is unsatisfactory, it is likely blown and needs to be replaced.
It is essential that you replace it if it is broken because it improves the sound quality of your computer. It also provides audio for your online meeting(s) (if you happen to have them).
With this in mind, make sure your laptop is turned off and unplugged from any outlets before removing the components.
Additionally, before you start to replace this component, gather all of your tools in one location. To keep your screws from getting lost, we recommend using the iFixit Magnetic Project Mat. Choose a location where there will be no children to interrupt you to prevent them from using potentially dangerous tools.
Tools
    1. Asus Chromebook Flip C302CA Speakers Replacement, Back Panel: step 1, image 1 of 1
      • Turn the laptop over so the bottom is facing you.
      Ask FixBot
    2. Asus Chromebook Flip C302CA Speakers Replacement: step 2, image 1 of 3 Asus Chromebook Flip C302CA Speakers Replacement: step 2, image 2 of 3 Asus Chromebook Flip C302CA Speakers Replacement: step 2, image 3 of 3
      • Remove two rubber caps on the top.
      • Remove the two 1 mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    3. Asus Chromebook Flip C302CA Speakers Replacement: step 3, image 1 of 3 Asus Chromebook Flip C302CA Speakers Replacement: step 3, image 2 of 3 Asus Chromebook Flip C302CA Speakers Replacement: step 3, image 3 of 3
      • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
      • Carefully remove the back panel using an opening pick.
      Ask FixBot
    4. Asus Chromebook Flip C302CA Speakers Replacement: step 4, image 1 of 2 Asus Chromebook Flip C302CA Speakers Replacement: step 4, image 2 of 2
      • Remove the back panel from the laptop.
      Ask FixBot
    1. Asus Chromebook Flip C302CA Speakers Replacement, Battery: step 5, image 1 of 3 Asus Chromebook Flip C302CA Speakers Replacement, Battery: step 5, image 2 of 3 Asus Chromebook Flip C302CA Speakers Replacement, Battery: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the sticker holding the cable using a pair of tweezers.
      • Detach the cable from the motherboard by lifting it up with a spudger.
      • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
      Ask FixBot
    2. Asus Chromebook Flip C302CA Speakers Replacement: step 6, image 1 of 2 Asus Chromebook Flip C302CA Speakers Replacement: step 6, image 2 of 2
      • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
      Ask FixBot
    3. Asus Chromebook Flip C302CA Speakers Replacement: step 7, image 1 of 1
      • Carefully lift up the battery from the front side to remove it from the laptop.
      Ask FixBot
    1. Asus Chromebook Flip C302CA Speakers Replacement, Speakers: step 8, image 1 of 3 Asus Chromebook Flip C302CA Speakers Replacement, Speakers: step 8, image 2 of 3 Asus Chromebook Flip C302CA Speakers Replacement, Speakers: step 8, image 3 of 3
      • Remove the two 2 mm screws from the speakers using a Phillips #00 screwdriver.
      Ask FixBot
    2. Asus Chromebook Flip C302CA Speakers Replacement: step 9, image 1 of 3 Asus Chromebook Flip C302CA Speakers Replacement: step 9, image 2 of 3 Asus Chromebook Flip C302CA Speakers Replacement: step 9, image 3 of 3
      Buy
      • Detach the cable that is connected to the motherboard using a pair of blunt tweezers.
      Ask FixBot
    3. Asus Chromebook Flip C302CA Speakers Replacement: step 10, image 1 of 2 Asus Chromebook Flip C302CA Speakers Replacement: step 10, image 2 of 2
      • Remove both speakers from the laptop and set them aside.
      Ask FixBot
Zahid Enriquez
543 Reputation
4 Guides authored
Gateway, Team 1-2, Saknee Spring 2022 Member of Gateway, Team 1-2, Saknee Spring 2022
GCC-SAKNEE-S22S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 56
All Time: 488
