Asus Chromebook Flip C302CA Display Replacement
  1. Asus Chromebook Flip C302CA Display Replacement, Back Panel: step 1, image 1 of 1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Display Replacement: step 2, image 1 of 3 Asus Chromebook Flip C302CA Display Replacement: step 2, image 2 of 3 Asus Chromebook Flip C302CA Display Replacement: step 2, image 3 of 3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Display Replacement: step 3, image 1 of 3 Asus Chromebook Flip C302CA Display Replacement: step 3, image 2 of 3 Asus Chromebook Flip C302CA Display Replacement: step 3, image 3 of 3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Display Replacement: step 4, image 1 of 2 Asus Chromebook Flip C302CA Display Replacement: step 4, image 2 of 2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Display Replacement, Display: step 5, image 1 of 1
    • Remove the black display ports from the motherboard.
  6. Asus Chromebook Flip C302CA Display Replacement: step 6, image 1 of 1
    • Remove the six 2.54 mm Phillips screws from the left and right screen hinge brackets.
  7. Asus Chromebook Flip C302CA Display Replacement: step 7, image 1 of 1
    • Remove the display unit.
  8. Asus Chromebook Flip C302CA Display Replacement: step 8, image 1 of 1
    • Use heat gun to loosen up adhesive on rubber covers for screw.
  9. Asus Chromebook Flip C302CA Display Replacement: step 9, image 1 of 1
    • Remove rubber covers.
  10. Asus Chromebook Flip C302CA Display Replacement: step 10, image 1 of 1
    • Remove the two 2.5 mm screws.
  11. Asus Chromebook Flip C302CA Display Replacement: step 11, image 1 of 1
    • Use prying tool to separate panel from monitor.
  12. Asus Chromebook Flip C302CA Display Replacement: step 12, image 1 of 1
    • Remove this connection by pulling to separate it from the monitor.
  13. Asus Chromebook Flip C302CA Display Replacement: step 13, image 1 of 1
    • Remove connection point and the entire camera assembly including wires.
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 16
All Time: 243
