Asus Chromebook C300MA-BBCLN12 Motherboard Replacement
  1. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Battery: step 1, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Remove the eight 9.0mm Phillips #00 screws.
    • Remove the three 6.0mm Phillips #00 screws.
  2. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 2, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 2, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 2, image 3 of 3
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 3, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 3, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 3, image 3 of 3
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
  4. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 4, image 1 of 1
    • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
  5. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 5, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 5, image 2 of 2
    • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
  6. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 6, image 1 of 1
    • Remove the battery from the bottom housing.
  7. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Motherboard: step 7, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Motherboard: step 7, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement, Motherboard: step 7, image 3 of 3
    • Remove the two 6.0mm Phillips #00 screws that secure the metal heat shield to the motherboard.
    • Remove the metal heat shield.
  8. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 8, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 8, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 8, image 3 of 3
    • Peel back the protective tape that covers the display cable connector.
    • Disconnect the display cable from the motherboard using the plastic spudger tool.
  9. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 9, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 9, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 9, image 3 of 3
    • Disconnect the speaker cable from the motherboard using the plastic spudger tool.
  10. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 10, image 1 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 10, image 2 of 3 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 10, image 3 of 3
    • Flip back the hinge that secures the blue daughterboard cable to the motherboard using the tweezers.
    • Disconnect the blue cable connecting the motherboard to the daughterboard by pulling on the blue cable tab.
  11. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 11, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 11, image 2 of 2
    • Remove the four 3.0mm Phillips #00 screws that attach the left hinge.
    • Remove the large silver 5.0mm Phillips #00 screw from the center-left side of the motherboard.
  12. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 12, image 1 of 2 Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 12, image 2 of 2
    • Remove the three 3.0mm Phillips #00 screws that secure the motherboard to the housing.
  13. Asus Chromebook C300MA-BBCLN12 Motherboard Replacement: step 13, image 1 of 1
    • Remove the motherboard.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 770
