Asus Chromebook C300M Bottom Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Asus Chromebook C300M Bottom Panel Replacement, Bottom Panel: step 1, image 1 of 1
      • Flip the Chromebook over, bottom-side up.
      Ask FixBot
    2. Asus Chromebook C300M Bottom Panel Replacement: step 2, image 1 of 2 Asus Chromebook C300M Bottom Panel Replacement: step 2, image 2 of 2
      • Remove the screws from the 11 spots using the aluminum driver with the J00 Philips head provided in iFixit toolkit.
      • Remove the eight 9.0mm Philips screws along the perimeter of the case.
      • Remove the three 6.0mm Philips screws from the center of the case.
      • Some versions may instead have six bigger screws (the four on the upper side of the image, close to the hinge, and two on the sides) and five smaller ones (four at the bottom of the image, where the laptop is thinner, and one in the center).
      Ask FixBot
    3. Asus Chromebook C300M Bottom Panel Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, work around the Chromebook separating the plastic case at the seam.
      Ask FixBot
    4. Asus Chromebook C300M Bottom Panel Replacement: step 4, image 1 of 1
      • Open the Chromebook at hinges.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 345
