Introduction
This is the replacement guide to replace the entire LCD assembly of the Asus Chromebook C213SA-YS02. This is a moderate procedure, and requires a purchase of the entire LCD assembly. This guide is used when your LCD display is not responding after troubleshooting has failed to solve the issue.
Power off the device by pressing and holding the power button on the side of the device.
Remove the power cable from the back of the device (if applicable).
Remove the seven black 4mm Phillips screws underneath the back cover.
Remove the eight black 7mm Phillips #00 screws along the edge of the device.
Remove the single silver 2mm Phillips #00 screw from the top of the Wi-Fi card.
Carefully pull the white and black wires out of the card using tweezers.
Remove the Wi-Fi card.
Flip the device over and open up the LCD screen.
Using the iFixit opening tool, gently place the tool in between the back-plate and the keyboard and lift up.
Slide the tool around the outside of the keyboard and lift up the tool while moving it around the boundary of the keyboard.
Pull the keyboard away from the back-plate. Be careful the keyboard cable is not caught on the back-plate while performing this maneuver.
Remove the two 4mm Phillips #00 stainless steel screws on one of the hinges.
Repeat the last step for the opposite hinge.
Carefully remove the LCD assembly off of the back plate. Be careful not to tug the LCD cable.
