Asus Chromebook C202SA-YS02 Palm Rest Replacement
  1. Asus Chromebook C202SA-YS02 Palm Rest Replacement, Palm Rest: step 1, image 1 of 1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Palm Rest Replacement: step 2, image 1 of 2 Asus Chromebook C202SA-YS02 Palm Rest Replacement: step 2, image 2 of 2
    • Carefully use the plastic opening tool to pry palm rest apart from bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Palm Rest Replacement: step 3, image 1 of 1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard. You may have to use a thin blade or spudger to lift open the respective latches.
Beau Hansen
845 Reputation
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 672
