Asus Chromebook C202SA-YS02 Bezel Replacement
  1. Asus Chromebook C202SA-YS02 Bezel Replacement, Bezel: step 1, image 1 of 1
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Bezel Replacement: step 2, image 1 of 1
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Bezel Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
Beau Hansen
845 Reputation
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 720
