Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Introduction
Go to step 1 ↓This is a tutorial on how to replace the back panel of an Asus Chromebook C202
What you need: 10 8mm screws, Tweezers, and a Phillips #1 Screwdriver
Remove Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
Use tweezers to get two of the screws are hidden by rubber caps along the rubber rest of the device out.
Tool used on this step:iFixit Opening Tool$1.99
What you need: plastic opening tool, Chromebook
Open the top portion of the Chromebook
To unhinge the top portion of the Chromebook, push down on the plastic opening tool.
Place the plastic opening tool facing upward using the upper scoop, into the edges between the front and back of the Chromebook.
In order to avoid damaging ribbon cables, gently lift the top portion of the Chromebook from the bottom portion.
