Asus Chromebook C101P Keyboard Replacement
  1. Asus Chromebook C101P Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Keyboard Replacement: step 2, image 1 of 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Keyboard Replacement: step 3, image 1 of 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Keyboard Replacement: step 4, image 1 of 2 Asus Chromebook C101P Keyboard Replacement: step 4, image 2 of 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Keyboard Replacement: step 5, image 1 of 3 Asus Chromebook C101P Keyboard Replacement: step 5, image 2 of 3 Asus Chromebook C101P Keyboard Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
3 other people completed this guide.
Bryan Acosta
401 Reputation
3 Guides authored
2 Guide Comments
This did not work my laptop won't turn on now. Any suggestions?
Destiny Wright - Reply
We’re sorry to hear that. We recommend you contact iFixit directly for support on this issue or to contact ASUS for further help.
Bryan Acosta -
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 30
All Time: 1,974
